I use a WHDG with SqlDataSource. I have a problem, that changes in the grid parent rows are updated in the database. In order to do that, made everything mentioned in http://help.infragistics.com/Help/NetAdvantage/ASPNET/2011.2/CLR4.0/html/WebHierarchicalDataGrid_Cell_Editing.html .
But when i change values in a child row the changes do not take place in the database. They only are stored when i add a new child row. Then the update fires.
Has anyone an idea what the problem could be? I use 11.1 of ASP.NET-library.
Martin
Hi Martin,
I'm glad you solved your issue.
Feel free to contact me if you have any other questions.
Hi Nikolay,
thank you for your answer and the example. In my case, i forgot to handle the RowUpdating-Event. This saves the data back to the database and everything works like i want.
Muchas Gracias
Please find attached the sample of editing behavior I created using the Northwind database.
If you have any questions, do not hesitate to ask.
