is there a way (or a sample) to enable validation in WHDG parent/child rows in order to check the value the user entered?
My second question is, if i can enter some default values in the new row. I tried DefaultValueAsString but that doesn't work for other datatypes.
Martin
Dear David,
thanks for your tipp. Because of it, i found the link http://beta.infragistics.com/community/forums/p/60897/309315.aspx .
Bye
Hi Martin,
We attempt to convert the DefaultValueAsString to an actual object before sending it down based on the type of the field. Do you have a DataType set for your columns to ensure the type is correct if there is no data?
regards,
David Young
