I want convert my whole Web page to PDF using
PdfDocument doc = new PdfDocument();
i didn't find any examples how to use PDFDocument class.
Can please some body help me.
Thansk in Advance.
I am using the other tool to convert Whole web page html to PDF format.
if you need information on the tool go to following link.
http://www.winnovative-software.com
I'm also trying to do the same thing. I want to export an HTML table as the header to my ultrawebgrid PDF export. Were you able to do this?
I want to export a HTML table as a PDF. Is it possible to do with UltraWebGridDocumentExporter?
Chris,
I have asked for something similar. I am able to use the Document libary for most of my printing needs, but I am allowing the customer to strore an HTML table that they use as a template in a database field.
However, when I try to print the table the AddRichContent method appears to strip off the HTML <table>, <tr>, and <td> tags.
I don't think this is the right area, but your answer - and more importantly one of your comments - is very close to pointing me in the necessary direction.
No but from your first post my guess was that you were trying to convert (or take) a web page (html) and turn it into a pdf file? Most pdf conversion/building tools really dont allow you to do that and while they do support tables etc. there is no direct way to grab a web page or html and convert it to pdf...
Help, I am so close
No but from your first post my guess was that you were trying to convert (or take) a web page (html) and turn it into a pdf file? Most pdf conversion/building tools really dont allow you to do that and while they do support tables etc. there is no direct way to grab a web page or html and convert it to pdf... well unless of course you want to basicly do a httpget on the page and capture the output to a image file and then insert image into pdf file... which I have done a few times...
What is it you are exactly trying to do?
