65
How can I determine if a SplitterPane within a WebSplitter is collapsable?
"By default, all panes are not collapsible, but still display a splitter bar. When a pane can collapse, a collapse icon appears in the splitter bar. The user can use the collapse icon to collapse the pane. "
http://ko.infragistics.com/help/topic/636ccb41-50e5-496f-9037-4d8234540e65
What determines whether or not a pane can be collapsed by it's WebSplitter parent? When I add a WebSplitter to the template of a SplitterPane (inside of another WebSplitter), the collapse button is visible for the outer WebSplitter, but is not visible for the nested WebSplitter.
  • 24497
    Hi pwooten,
    Thank you for report.
    That was accidental mistype for default value in initializer of client side CollapsedDirection property of SplitterPane. It had default value of 1 instead of 0. So, if application did not set value SplitterPane.CollapsedDirection, than codes like below, would return 1 instead of 0.
    function checkDir(id) {
    var splitter = $find('<%=WebSplitter1.ClientID%>');
    var pane = splitter.get_panes()[0];
    var dir = pane.get_collapsedDirection();
    alert('dir:' + dir);
    That issue had beed fixed and update will be available in service releases.
