40
Infragistics version Version=6.1.20061.1038 + .Net 3.5
Does Infragistics web controls (Version=6.1.20061.1038) work on .Net 3.5?
  • 10880
    NetAdvantage 2008 Volume 1 is the first volume that is supported on the 3.5 Framework and Visual Studio 2008.  Any other versions that are using in either of those two environments has not been tested,
    If you are deploying on an application you created using Visual Studio 2003 or Visual Studio 2005 to a server that uses the .NET 3.5 framework, it *should* work.
    If you trying to develop in the 3.5 environment along with Visual Studio 2008, you may run into numerous issues.  One of them deals with the fact that the 3.5 Framework incorporates the ASP.NET AJAX 1.0 Framework which was not supported till 6.3.20063.1059.  If you try to use any of the AJAX functionality, you will have issues.  There may also be some impatibilities with the new design surface and our older designer files.
    In short, you can use this version in Visual Studio 2008 and .NET 3.5 but it is highly not recommended and most importantly not supported.
