I've got a user on IE6 reporting they cannot see all their vertical menu items: only the first. It is specific to that workstation so it has not been a big concern. When they "view source" all menus/items are in the HTML. This had occured on 2 other machines (both IE7) a few months back but they ended up rebuilding hte machines (complete OS re-install). I had personally seen an issue with only the last menu not being visible (when it was an odd number 3rd, 5th, 7th, etc) in a previous release so I setup a sample project with 11.2.20112.2159 to test. On my DEV machine (XP3 w/IE8) I have 2 menu items defined in code-behind and I'm only seeing the 1st; however, all items appear in "view source". When I add a 3rd menu I see the first two but not the 3rd. By not setting the width of the menu, you can see it is "longer" to support the extra item you cannot see. My menu is setup in Site.Master and I have the IE7ZIndexAdjust fix in place to ensure the menu appears in front of controls on child pages. I've attached the sample solution. Any help would be appreciated.
HI Support,
I m having the same problem. My WebDataMenu is not working in IE7. but it works fine in IE8,IE9, etc. Im ausing infragistics version 12.1. I went through someone responded as when the browser zoom % increased it displays the menu.
I m getting the exact problem. When i increase the zoom percent it appear, but again my menu vanish if i select any item from the menu.
My Menu Orientation Is Horizontal.
Please let me know your response.
Jamuna.
Setting the "zoom" to 100% in IE avoids the issue. Some percentages will make the last menu disappear. The users were unknowingly changing the zoom setting via mouse wheel. No resolution from a code perspective as of yet.
I'm having the same issue on Windows XP SP3 using IE8. Has this been resolved yet?
Thanks,Calvin Nguyen
Hello dc06663,
Thank you for your patience. I have been able to reproduce this issue in Windows XP SP3 using IE6. I have logged this issue with our development team with an ID of 121603 and am creating a private case for you. You can access the private case by using the following link:
https://ko.infragistics.com/my-account/support-activity
Sincerely,Mike P.Developer Support EngineerInfragistics, Inc.www.infragistics.com
Thank you for your patience. Setting up the environment to test this issue is taking longer than I thought. I will continue looking into this matter and will provide you with a progress update by the end of the day Monday.
