I have a WebDataMenu that is initially loaded on Page Load, but not for postbacks. The problem is that when I hover over a parent menu and the submenu items are displayed, moving the mouse down to select a submenu item causes them to disappear. Generally, I get one or two parent menus that will work properly, but the rest will hide the submenu list when I try to select something. It isn't always the same one, that part seems to be random. only by clicking repeatedly on the parent menu will the submenu finally stay put so something can be slected. I am using VS2008SP2, Infragistics 3.5 10.3.20103.2134. I cannot upgrade controls at this time and must make this work before 10/1 launch date. Any suggestions?
Sorry Our version is ASP.NET_12.1.20121.2072. WE have the same problem. Submenu disappears before we select. I went through the video (avi) posted by the other user. we are facing exactly the same issue.
Please let us know your response asap.
Jamuna.
Hi Support,
We are using Infragistics version ASP.NET_12.1.20121.2137. But still facing the exact problem in many browsers like Firefox, IE, etc..
Please confirm.
Thanks for your help. I seemed to have found a workaround for the issue by removing the height property of the menu.
Hello Paul,
This issue has been addressed in service release versions ASP.NET_12.2.20122.2031, ASP.NET_11.2.20112.2225, ASP.NET_12.1.20121.2137. As we no longer provide service releases for 11.1. I suggest you to upgrade to 11.2 or later.
Hope this helps.
I'm having the same issue as described above, has there been a fix or workaround issued? Version 11.1.
