How to display icons in the WebDataMenu items?
Hello Avinash,
If you need any other questions, please let me know.
Try setting ImageURL="~/Images/Icons/home.png".
Hope this helps.
No, I want to give my own path for Images. And when I set ImageURL="/Images/Icons/home.png", it appends "ig_res/Default" before my path, and my images are not shown.
I investigated to override this path and found that, we can override it through config file, but it overrides for all the infragistics controls of the project. I want to override it only for WebDataMenu control, and which is not working.
Let me know if you need any further assistance with the matter.
Hi Avinash,
You can add icons to menu items using the ImageUrl property:
<ig:DataMenuItem Text="Documents" ImageUrl="ig_res/Default/images/igdt_folder.gif" > </ig:DataMenuItem>
Here is a demonstrative sample of this - http://ko.infragistics.com/products/aspnet/sample/data-menu/data-binding. Also you could use templates - http://ko.infragistics.com/products/aspnet/sample/data-menu/templates.
Please do not hesitate to ask if you have any questions.
