45
Problems with Webschedule & Recurrence
Hello:
I am having problems with a very simple page where I want to mimic the retrieval of appointments and their recurrence, and showing them on a WebWeeklyView.  For that effect, I have hardcoded 2 appointments of which one is a recurrent appointment.  When I do this experiment only with the 2 appointments, it works fine; however, when I add recurrence to one of them , the WeeklyView displays fine (including the recurrence icon) but when I double-click on any of the recurrent appointments it gives a jscript error.  Here's the code:
DEFAULT.ASPX.CS
using System;
using System.Data;
using System.Configuration;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
// added by A.L.
using Infragistics.WebUI.Shared;
using Infragistics.WebUI.WebSchedule;
// end
public partial class _Default : System.Web.UI.Page
    protected void Page_Load(object sender, EventArgs e)
    private void Page_PreRender(object sender, EventArgs e)
        this.WebScheduleInfo1.DataBind();
        Appointment myAppointment = this.CreateAppointment("1");
        this.WebScheduleInfo1.Activities.Add(myAppointment);
        // add second activity
        myAppointment = this.CreateAppointment("2");
    private Appointment CreateAppointment(string ActivityKey)
        // Create an empty Activity owned by the WebScheduleInfo.
        Appointment appt = new Appointment(this.WebScheduleInfo1);
        // Set pertinent properties on the Activity.
        appt.Subject = "Appointment Created at: "+ System.DateTime.Now.ToString();
        double dOffset = Convert.ToDouble(ActivityKey);
        appt.StartDateTime = SmartDate.Parse(System.DateTime.Now.AddDays(dOffset).ToString());
        appt.Duration = new TimeSpan(0, 30*int.Parse(ActivityKey), 0);
        int tempKey = int.Parse(ActivityKey);
        // RECURRENCE CREATION
        if (tempKey % 2 == 0) // create recurrence for appts with an even key
            appt.CreateRecurrence();
            Recurrence recurrenceObject = appt.Recurrence;
            recurrenceObject.Period = RecurrencePeriod.Daily;
            recurrenceObject.PeriodMultiple = 1;
            recurrenceObject.EndDateUtc = appt.StartDateTime.AddDays(2);
            recurrenceObject.Key = ActivityKey;
        // END RECURRENCE CREATION
        // Set Key property to a unique value on each appointment.
        appt.Key = ActivityKey;
        // Set ResourceKey property to link Activity with organizing Resource.
        appt.ResourceKey = this.WebScheduleInfo1.VisibleResources.UnassignedResource.Key;
        appt.Location = "My Location here";
        appt.Description = "Customized decription";
        appt.EnableReminder = false;
        // Return the newly initialized Activity.
        return appt;
DEFAULT.ASPX
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register Assembly="Infragistics2.WebUI.UltraWebToolbar.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.UltraWebToolbar" TagPrefix="igtbar" %>
<%@ Register Assembly="Infragistics2.WebUI.WebSchedule.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.WebSchedule" TagPrefix="ig_sched" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title>Harmony: Appointment Weekly</title>
    <script type="text/javascript" >
    // JScript File
function OpenAppointmentDetail(oScheduleInfo, oEvent, oDialog, oActivity)
    var eventID = oActivity.getDataKey();
    var startDate = oActivity.getStartDateTime();
    oEvent.cancel = true;
    /* Call different dialog */
    window.open('AppointmentDetail.aspx?eventID=' + eventID + '&startDateTime=' + startDate);
function UltraWebToolbar1_Click(oToolbar, oButton, oEvent){
switch (oButton.Key)
 case "deleteTool":
  var weekView = ig_getWebWeekViewById("WebWeekView1");
  /*var scheduleInfo = ig_getWebScheduleInfoById("WebScheduleInfo1");*/
  var activity = weekView.getSelectedActivity();
  if(activity != null)
   alert('Attempting to delete eventID = '+ activity.getDataKey());
  if (activity == null)
      alert('Need to select an appointment to delete');
  oEvent.needPostBack = false;
  break;
</script>
</head>
<body>
    <form id="form1" runat="server">
        &nbsp;<igtbar:UltraWebToolbar ID="UltraWebToolbar1" runat="server" BackColor="White"
            BackgroundImage="blueexplorer.gif" BorderStyle="None" Font-Names="Arial" Font-Size="8pt"
            ForeColor="Black" Height="22px" ImageDirectory="/ig_common/images/" ItemSpacing="0"
            ItemWidthDefault="80px" MovableImage="ig_tb_move03.gif"
            Width="551px">
            <HoverStyle BackColor="Bisque" BackgroundImage="None" BorderColor="Navy" BorderStyle="Solid"
                BorderWidth="1px" Cursor="Default" Font-Names="Arial" Font-Size="8pt" ForeColor="Black">
            </HoverStyle>
            <DefaultStyle BackgroundImage="blueexplorer.gif" BorderColor="Menu" BorderStyle="Solid"
                BorderWidth="0px" Font-Names="Arial" Font-Size="8pt" ForeColor="Black">
            </DefaultStyle>
            <Items>
                <igtbar:TBarButton DisabledImage="" HoverImage="" Image="" SelectedImage="" Text="Delete"
                    ToolTip="Delete Selected Appointment" Key="deleteTool">
                </igtbar:TBarButton><igtbar:TBSeparator />
                <igtbar:TBarButton DisabledImage="" HoverImage="" Image="" SelectedImage="" Text="Go To Parent"
                    ToolTip="Go To Parent of Selected Appointment" Key="gotoParentTool">
            </Items>
            <SelectedStyle BackColor="Orange" BackgroundImage="OrangeExplorer.gif" BorderColor="Navy"
                BorderStyle="Solid" BorderWidth="1px" Cursor="Default" Font-Names="Arial" Font-Size="8pt"
                ForeColor="Black">
            </SelectedStyle>
            <ClientSideEvents Click="UltraWebToolbar1_Click" />
        </igtbar:UltraWebToolbar>
        <div>
            <ig_sched:webweekview id="WebWeekView1" runat="server" webscheduleinfoid="WebScheduleInfo1"></ig_sched:webweekview>
        </div>
        <ig_sched:webscheduleinfo id="WebScheduleInfo1" runat="server" AppointmentFormPath="AppointmentDetail.aspx" >
            <ClientEvents ActivityDialogOpening="OpenAppointmentDetail" />
        </ig_sched:webscheduleinfo>
    </form>
</body>
</html>
APPOITNMENTDETAIL.ASPX.CS
using System;
using System.Data;
using System.Collections;
using System.Web;
public partial class AppointmentDetail : System.Web.UI.Page
        if (Request.Params["eventID"] != null && Request.Params["eventID"].ToLower() != "null")
            this.lblEventID.Text = "The appointment you selected is: " + Request.Params["eventID"];
        else
            this.lblEventID.Text = "New Appointment requested on : " + Request.Params["startDateTime"];
APPOINTMENTDETAIL.ASPX
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="AppointmentDetail.aspx.cs" Inherits="AppointmentDetail" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" >
    <title>Harmony: Appointment Detail</title>
</head>
<body>
    <div>
        <asp:Label ID="Label1" runat="server" Font-Size="XX-Large" Text="This is your appoinment Detail"></asp:Label><br />
        <br />
        <asp:Label ID="lblEventID" runat="server" Font-Size="Large" Text="The appointment you selected is ... "></asp:Label>&nbsp;</div>
    </form>
</body>
</html>
This code works OK if I remove the block between // RECURRENCE CREATION and // END RECURRENCE CREATION in Deafault.aspx.cs.
Any help would be appreciated.
antonioalm
