I have a situation with ultrwebtoolbar's customrules. In my web form, I have to add 16 jquery enabled Calender or datepicker controls. Some of the buttons defined in ultrawebtoolbar's are suppose to be hidden and defined as btn.DefaultStyle.CustomRules = "DISPLAY: none". It does work perfectly as long as the # of datepicker controls are 15. As soon as I add next picker making it 16th datepicker control, then customrules seems not working displaying all the button defined. So example would be, it is suppose to hide , 'Approval', 'Duplicate' buttons. And it does work, however, as soon as I add extra date picker control making it 16th control, then it display all of the button including 'Approval', 'Duplicate' buttons. It is only happening in IE(I am using 9.0).
Anybody could enlighten me.
I would appreciate it.
I got the work around for this issue.
thanks Nikolay
Hello ezpal,
I'm just checking if you still need assistance with the matter.
Hi ezpal,
Can you attach the complete project as I'm not able to run this because I don't have the ScriptControls assembly. Thanks.
I have decide to post a simple form that I created to test it, run this one and look for the tool bar. Then add extra calender and run it the tool bar look differentthere are about 28 jquery calenders defined in scriptcontrols assembly. if you run this page the tool control work as it is define. As soon as you add next calender then you will see all the button defined in ucToolbar.ascx. I hope this will help to look into the issue<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="WebForm1.aspx.vb" Inherits="csg.mis.crforms.WebForm1" %><%@ Register TagPrefix="uc1" TagName="ucToolbar" Src="../UserControls/ucToolbar.ascx" %><%@ Register Assembly="csg.mis.common.ScriptControls" namespace="csg.mis.common.ScriptControls" tagprefix="ScriptControls" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"><title></title><script type="text/javascript" src="/mis/scripts/jquery-1.5.1.min.js"></script></head><body><form id="form1" runat="server"><uc1:uctoolbar id="ToolBar" runat="server"></uc1:uctoolbar><ScriptControls:Calendar ID="txtProjStartDate" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate0" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate1" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate2" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate3" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate4" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate5" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate6" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate7" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate8" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate9" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate10" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate11" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate12" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate13" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate14" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate15" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate16" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate17" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate18" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate19" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate20" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate21" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate22" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate23" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate24" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate25" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate26" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate27" runat="server" CssClass="formInputBoxText" /><ScriptControls:Calendar ID="txtProjStartDate28" runat="server" CssClass="formInputBoxText" /></form></body></html>
On code behind all I have is
Public Class WebForm1Inherits System.Web.UI.PageProtected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.LoadToolBar.HideButtons(New String() {"Cancel", "Approve", "RtntoDraft", "Exit"})End SubEnd Class
in user control HideButtons is defined as
'<summary>
' Remove buttons from an infragistics toolbar.
' pass in the toolbar and a string array of button keys to be removed.
'</summary>
Public Sub HideButtons(ByVal keys() As String)
Dim btn As TBarButton
Dim key As String
For Each key In keys
btn = _toolbar.Items.FromKeyButton(key)
If Not IsNothing(btn) Then
End If
Next
End Sub the webtoolbar is defined as follow<%@ Control Language="vb" AutoEventWireup="false" Codebehind="ucToolbar.ascx.vb" Inherits="csg.mis.crforms.ucToolbar" TargetSchema="http://schemas.microsoft.com/intellisense/ie5" %>
<%@ Register Assembly="Infragistics4.WebUI.UltraWebToolbar.v10.3, Version=10.3.20103.2088, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebToolbar" TagPrefix="igtbar" %>
<igtbar:ultrawebtoolbar id="_toolbar" CssClass="NoPrint" runat="server" Width="669px" borderstyle="None"
backcolor="White" Font-Names="Arial" Font-Size="9pt" Height="24px" BackgroundImage="/ig_common/webtoolbar2/blueexplorer.gif"
MovableImage="/ig_common/webtoolbar2/ig_tb_move03.gif" ItemWidthDefault="93px" ItemSpacing="0">
<HoverStyle Cursor="Default" borderwidth="1px" BorderColor="Navy" borderstyle="Solid"
backcolor="DarkOrange" TextAlign="Left"></HoverStyle>
<ClientSideEvents Click="ToolBar_Click"></ClientSideEvents>
<SelectedStyle Cursor="Default" borderwidth="1px" BorderColor="Navy" borderstyle="Solid"
backcolor="Gainsboro" TextAlign="Left"></SelectedStyle>
<Items>
<igtbar:TBarButton Key="Save" ToolTip="Save this Request" Text="Save" Image="/images/common/save.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="SaveandExit" ToolTip="Save this Request and Exit" Text="Save & Exit" Image="/images/common/save.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="Cancel" ToolTip="Set the status of this Request to cancelled" Text="Cancel"
Image="/images/common/cancel.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="Submit" ToolTip="Submit this Request and commence workflow" Text="Submit" Image="/images/common/ok.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="Approve" ToolTip="Approve this request" Text="Approve" Image="/images/common/Approve.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="RtntoDraft" ToolTip="Return this Request to draft" Text="Rtn to Draft" Image="/images/common/negative.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="Send" ToolTip="Opens your mail client to send a link to this Request" Text="Send"
Image="/images/common/mail.gif"></igtbar:TBarButton>
<igtbar:TBarButton Key="Duplicate" Text="Duplicate" Image="/images/common/copy.gif">
<DefaultStyle CustomRules="DISPLAY: none"></DefaultStyle>
<igtbar:TBarButton Key="Print" ToolTip="Print Preview" Text="Print" Image="/images/common/print.gif">
</Items>
<DefaultStyle borderwidth="0px" BorderColor="Menu" borderstyle="Solid" BackgroundImage="/ig_common/webtoolbar2/blueexplorer.gif"
TextAlign="Left"></DefaultStyle>
</igtbar:ultrawebtoolbar>
Try to attach the pictures from the Options tab when you are writing a reply.
