I have a client who was experiencing some issues with the WebDataMenu in IE8. The menu clicking worked fine but she was unable to scroll to the right on the menu (more menu items). I turned compability off and the menu was now able to scroll. This setting is something corporate pushes down to the machines so I have to tweak my code to get the menu working in IE8 compatability mode. How do I do this?
Hello jayanthi,Did you have the chance to look at our online sample - http://ko.infragistics.com/products/aspnet/sample/data-menu/data-binding (when installing our products you can chose to install it locally) where there are a couple of samples containing full code of the menu. I would advise you to open up a new support ticket or new forum thread because your issue is not the same as the one from this thread. Also please provide which version of netadvantage you are using.
im new to infragistics . i add a webdatamenu & script manager in my website.it will show 'namespace or type specified in the imports 'system.web.ui.navigationcontrols' im using asp.net2.0 and oracle as backend . pls help me how to add the control [ give a sample page with contains design & coding]
Hello Kevin,Please let me know if you have any further questions regarding this issue.
Hello Kevin,Please take a look at the attached sample i used to test under Win 7 and IE 8. Can you please provide steps to reproduce via the sample or create a new one and provide steps to reproduce with it? Although if you are using a different build for 11.2 please let me know.
