We have Visual Webpart which has tree inside webdropdown and you can select multiple items in from the tree.Everything works fine but only issue is the drop down is not getting closed when user is clicking outside the control.
I have included the aspx code just in case.
function closeGlobalDropDown(sender, eventArgs) { setTimeout("closeGlobalDropDownImpl();", 10); } function closeGlobalDropDownImpl() { //ig_controls.ctlRegionCountryPicker_drpCountries._elements["Input"].focus(); $find('<%=drpGlobal.ClientID%>')._elements["Input"].focus(); }
function drpGlobal_DropDownClosed() { updateCountryDropdown(); $get("<%=btnGlobal.ClientID%>").click(); }
function updateCountryDropdown() { //get the checked tree items }</script><asp:UpdatePanel runat="server" ID="up" UpdateMode="Conditional" > <ContentTemplate> <table> <tr> <td> <ig:WebDropDown runat="server" ID="drpGlobal" DisplayMode="ReadOnlyList" EnableClosingDropDownOnSelect="False" ClientEvents-DropDownClosed="drpGlobal_DropDownClosed" DropDownAnimationDuration="0"> <Templates> <ig:ItemTemplate TemplateID="template"> <Template> <ig:WebDataTree ID="tree" runat="server" Enabled="True" Height="185px" CheckBoxMode="TriState" OnLoad="tree_Load" AnimationDuration="0" InitialExpandDepth="1" SelectionType="None" Width="290px"> <ClientEvents NodeClick="closeGlobalDropDown" NodeExpanded="closeGlobalDropDown" NodeCollapsed="closeGlobalDropDown" NodeChecking="closeGlobalDropDown" /> </ig:WebDataTree> </Template> </ig:ItemTemplate> </Templates> <Items> <ig:DropDownItem Value="Test" Selected="False" TemplateId="template" /> </Items> </ig:WebDropDown> </td> </tr> </table> </ContentTemplate></asp:UpdatePanel>
Please let me know if I'm missing something.
Thanks,Sanjay
Hello Sanjay,
I have attached the issue with our developers in our tracking system, with an existing issue ID of # 125263.
I have opened a private support case CAS-102606-C7D4S7. I will provide more details on this support case.
I hope this helps.
I was able to see the behavior you described after I check values in the checkboxes of tree node. I have used below mark up with version 12.1.20121.2072.
<ig:WebDropDown runat="server" ID="drpGlobal" DisplayMode="DropDownList" Width="200px"> <Items> <ig:DropDownItem Key="key1"></ig:DropDownItem> </Items> <ItemTemplate> <ig:WebDataTree ID="tree" runat="server" Height="185px" CheckBoxMode="TriState" Width="290px"> <Nodes> <ig:DataTreeNode Text="One" Value="1"></ig:DataTreeNode> <ig:DataTreeNode Text="Two" Value="2"></ig:DataTreeNode> <ig:DataTreeNode Text="THree" Value="3"></ig:DataTreeNode> <ig:DataTreeNode Text="Four" Value="4"></ig:DataTreeNode> </Nodes> </ig:WebDataTree> </ItemTemplate> </ig:WebDropDown>
I am looking for a way to implement this functionality. I will update you further with more details on this.
