I am using the 12.1 WebUpload control.
The control works as excepted except if the file uploaded is too large. In this case the UploadFinished event fires with e.FileStatus = Infragistics.Web.UI.EditorControls.UploadStatus.FileSizeExceeded. Since the upload is not valid I return, but the page still sends a post request to "/ig_fua34sf345sdf13sdf3454erdsf2345asd3425df5235d54df345.aspx?key=qnyBdolkJb5frwLmgoRfmC0dkSh9fM&cid=5be9523d-dd21-4a3e-8788-494a72cadf82".
This post fails, resulting in Global.asax logging the failure.
As far as I can tell, this is the URL where progress updates are normally requested from.
I tried to cancel the upload, but since the UploadStarting and UploadFinishing events are not fired (goes strait to the UploadFinished event) and the UploadFinished event does not have a cancel option, this is not possible.
How do I prevent this error? or is this a bug with the control?
Code:
Protected Sub webUpload1_UploadFinished(ByVal sender As Object, ByVal e As Infragistics.Web.UI.EditorControls.UploadFinishedEventArgs) Handles webUpload1.UploadFinishedIf e.FileStatus <> Infragistics.Web.UI.EditorControls.UploadStatus.Finished Then Return ' 'If file is not finished then it is in some sort of error state and does not need to be processed.'Process the uploaded file.End Sub
Exception:
ErrorType: System.Web.HttpExceptionMessage: The file '/ig_fua34sf345sdf13sdf3454erdsf2345asd3425df5235d54df345.aspx' does not exist.Source: System.WebStackTrace:
at System.Web.UI.Util.CheckVirtualFileExists(VirtualPath virtualPath)at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean throwIfNotFound)at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp)at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)at System.Web.UI.PageHandlerFactory.System.Web.IHttpHandlerFactory2.GetHandler(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)at System.Web.HttpApplication.MapHttpHandler(HttpContext context, String requestType, VirtualPath path, String pathTranslated, Boolean useAppConfig)at System.Web.HttpApplication.MapHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Data (0):
Hello Ted,
I tried this with the latest version of NetAdvantage for ASP.NET - v13.1.2107 and was not able to reproduce this. I attached my sample to this post for you, so please review it and feel free to let me know if I misunderstood you or if you have any other questions.
Also, the server error occurs before the OnError client event.
