1253
ItemTemplate help
I have the following code:
protected override void OnInit(EventArgs e)
    base.OnInit(e);
    myTemplate temp = new myTemplate();
    ItemTemplate template = new ItemTemplate();
    template.Template = temp;
    template.TemplateID = "template1";
    WebDataGrid1.Templates.Add(template);
protected void Page_Load(object sender, EventArgs e)
     if (!IsPostBack)
          TemplateDataField templateColumn1 = (TemplateDataField)this.WebDataGrid1.Columns["TemplateColumn1"];
          templateColumn1.ItemTemplate = new myTemplate1();
          WebDataGrid1.DataSource = populateGrid();
          WebDataGrid1.DataBind();
protected DataTable populateGrid()
     DataTable dt = new DataTable();
     dt.Columns.Add("ID");
     dt.Columns.Add("Name");
     DataRow row;
     for (int i = 0; i < 10; i++)
          row = dt.NewRow();
          row.SetField<Int32>("ID", i);
          row.SetField<string>("Name", "Name" + i);
          dt.Rows.Add(row);
     return dt;
protected void WebDataGrid1_ItemCommand(object sender, HandleCommandEventArgs e)
My question is that if I remove the if (!IsPostBack) statement then the button in the ItemTemplate is firing the ItemCommand event.  I need the IsPostback statement.  Is there a way to solve this issue?  Thanks!
