I've got a problem with webnumericeditor
I use it in a rowedittemplate and it is bound to a datafield of type Long (or whatever)
If the value is for instance "45,37" the set_value will be 4537, so the webnumericeditor will top to the max value (which is 100 in my case)
When you enter a value like "31,74" in the webnumericeditor and commit, the correct value is passed to the code behind
I had many tentatives with culture and even replaced it by a webmaskeditor, but I always have this problem of initial parsing during the set_value, for which the {value} parameter has no more comma
Could someone direct me to a solution please?
Many thanks!
Hello Antoine,
I have created a support ticket on your behalf with number CAS-104733-W6J8X1. I have linked this case with Development issue #128044. You can view its status on our website - go to Account - Support Activity, select your case and click the Development Issues tab.
Hi Antoine,
I could suggest you a possible workaround - set EnableScriptGlobalization property of the ScriptManager to true, and if then a point appears in the editor, instead of a comma, you could replace it in the TemplateOpened client-side event, for example:
function onTemplateOpened(sender, args) { var newVal = document.getElementById('WebDataGrid1_ret_WebNumericEditor1').value.replace('.', ','); document.getElementById('WebDataGrid1_ret_WebNumericEditor1').value = newVal;}
Also, you should set the same culture for your page and the WebNumericEditor.
I am attaching a small sample for your reference.
As I'm still looking into this, I will update you as soon as I have more information.
