I am trying to create a context menu on a single click. I have the code ready to implement this. However I am trying to find out the right object/events to use.
Lets say one day has an appointment set, and one day does not. What event can I use or what objects can I use through Javascript to see if the day that was just clicked on has an appointment set?
Here is the current event I am using, which works, but when I click on an appointment nothing fires.
function WebScheduleInfo1_ActiveDayChanging(oScheduleInfo, oEvent, oOldDate, oNewDate) { console.log(oScheduleInfo); console.log(oEvent); console.log(oOldDate); console.log(oNewDate);
Which object will hold the value of weather an appointment is set that day or not?
If you need any further assistance with the matter, please feel free to contact me.
Hi OmegaPrime,
You could check what element is clicked from the MouseDown event and then access it in ActiveDayChanged. If it is not a button, execute your code. For example:
var el;function onMouseDown(oWebMonthView, oEvent, element) { el = element;}
function onActiveDayChanged(scheduleInfo, e, newDate) { if (el.tagName != "BUTTON") {...}
Hope this helps.
To expand on this bug further, when you click the Previous Month or Next Month button, this event fires and is popping up my context menu. There has to be a way to prevent at least that from happening?
Is there no way around this? No way to check if the click resulted on a scroll bar? If not, I appreciate all the help you have given me. :)
It seems that this is not possible. And it is expected ActiveDayChanging to be fired because even if you click the scroll arrow, the active day still changes.
