635
Sorting on a hidden field fails
I've a column in a grid holding an image (index =0) representing state an image which when the sort is triggered should sort on a hidden column (index =3).
protected void ColumnSorted(object sender, SortingEventArgs e)
        if (e.Column.Index != 0)
            RepopoulateScreenVariables();
            this.gridTranslations.DataSource = _AfterDataTableGrid.DataTableView;
            this.gridTranslations.DataBind();
        else
            //try to create a new Event that clicks the 3rd column/Status
            //then recall this function
            e = new SortingEventArgs(
                        new SortedColumnInfoCollection(this.gridTranslations),
                        this.gridTranslations.Columns[3]);
            Column_Sort(sender, e);
However, when it recalls the function with the new event arg it fails, I'm assuming this is because the event has fired after the sorting has occurred.
I can't seem to find an example/way of redirecting the column click.
Does anyone have any ideas?
Cheers
  • 29417
    Suggested Answer
    Hello murray7
    You can cancel the default sorting by clearing the sorted columns collection and adding your own column to sort by after that . For example:
    protected void WebDataGrid1_ColumnSorted(object sender, Infragistics.Web.UI.GridControls.SortingEventArgs e)
            if (e.Column.Index == 1)
                e.SortedColumns.Clear();
                e.SortedColumns.Add(this.WebDataGrid1.Columns[0],Infragistics.Web.UI.SortDirection.Descending);
            this.WebDataGrid1.DataSource = MakeTable();
    In this case if the sorted column is with index 1 then cancel the default sorting and sort the column with index 0 in descending order.
    Also if you’re not providing the data source anywhere else in the page lifecycle then you need to do it in that even so that you’ll have a  data source each time you sort.
    Let me know if you have any questions or concerns.
    Best Regards,
    Maya Kirova
    Developer Support Engineer
    Infragistics, Inc.
