295
Grid error on tree node change.
I have a webdatatree that control data selection on grid base on ID (department_id).
My problem is when user edit a cell but did not click save, click on another cell and then select another node on the tree I will get this error:
how can I avoid this error and prompt the user if the grid is dirty to save or to continue to another node without saving?
Zaid
Requested record cannot be found by key.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: Infragistics.Web.UI.GridControls.MissingRecordException: Requested record cannot be found by key.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[MissingRecordException: Requested record cannot be found by key.]
   Infragistics.Web.UI.GridControls.EditingCore.OnAction(String actionType, Object id, Object value, Object tag) +1039
   Infragistics.Web.UI.GridControls.GridBehavior.Infragistics.Web.UI.GridControls.IGridBehavior.OnAction(String actionType, Object id, Object value, Object tag) +48
   Infragistics.Web.UI.GridControls.GridBot.LoadAdditionalClientState(Object state) +1318
   Infragistics.Web.UI.Framework.RunBot.HandleRaisePostDataChangedEvent() +204
   Infragistics.Web.UI.GridControls.GridBot.HandleRaisePostDataChangedEvent() +73
   Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.RaisePostDataChangedEvent() +37
   System.Web.UI.Page.RaiseChangedEvents() +134
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5201
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="WebForm3.aspx.cs" Inherits="voltsweb2.WebForm2" %>
<%@ Register src="WebUserControl1.ascx" tagname="WebUserControl1" tagprefix="uc1" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
</head>
<body>
function WebDataGridView_ExitingEditMode(webDataGrid, eventArgs) {
alert("exitexitmode");
///<summary>
/// If the a field in Column "Basename" is not "Standard" then set the values for columns "TextA" and "TextB"
///</summary>
///<param name="sender" type="Infragistics.Web.UI.WebDataGrid"></param>
///<param name="eventArgs" type="Infragistics.Web.UI.CancelEditModeEventArgs"></param>
var answers;
var grid;
var cellName;
var theVal;
var theotherval;
var cell = eventArgs.getCell();
var othercell = cell.get_row().get_cellByColumnKey("B");
cellName = cell.get_column().get_key();
//the next code row gets the wrong value, it is the former value not the actual selected!!
theVal = cell.get_value().toLowerCase();
theotherval = cell.get_row().get_cellByColumnKey("B").get_value();
othercell.get_element().style.backgroundColor = 110030;
//the actual selected value can be found in the eventArgs!
//theVal = eventArgs.get_displayText()
alert(cellName + theVal);
alert(cellName + theotherval);
// if (cellName == "Basename") {
// if (theVal != "") {
// if (theVal != "standard") //if not Standard then set the default values
// strReturn = searchWdg2(theVal); //here I do a "lookup" in another grid, you can also have these values already or do a query....
// answers = strReturn.split(":"); //I get 2 values in one string separated by ":" and convert this to an array
// impBCell = cell.get_row().get_cellByColumnKey("TextA");
// impBCell.set_value(answers[0]); //put in the first value of the array
// impFCell = cell.get_row().get_cellByColumnKey("TextB");
// impFCell.set_value(answers[1]); //put in the second value of the array
function WebDataGridView_EnterEditMode(webDataGrid, evntArgs) {
// alert("enteredit");
// var row = evntArgs._cell._row;
// var cell = evntArgs._cell;
// alert(row.get_cellCount());
// alert(cell.value);
//var selectedCell = evntArgs.getSelectedCells().getItem(0);
//gets the value of the cell
//var cellValue = selectedCell.get_value();
//alert(cellValue);
function WebDataGrid1_Selection_CellSelectionChanged(sender, eventArgs) {
// alert("cellchange");
// var selectedCell = eventArgs.getSelectedCells().getItem(0);
// var cellValue = selectedCell.get_value();
// alert(cellvalue);
function changecell() {
alert("changecell");
</script>
<form id="form1" runat="server">
<div>
<asp:Label ID="Labelx" runat="server" Text="280" CssClass="label" ></asp:Label>
<ig:WebDataTree ID="WebDataTree2" runat="server" DataSourceID="WebHierarchicalDataSource1"
Height="241px" Width="236px" SelectionType="Single" OnSelectionChanged="WebDataTree2_OnSelectionChanged"
style="margin-right: 0px" >
<DataBindings>
<ig:DataTreeNodeBinding DataMember="HR_DEPT_DefaultView"
KeyField="DEPARTMENT_ID" TextField="DEPARTMENT_NAME"
ValueField="DEPARTMENT_ID" />
</DataBindings>
<AutoPostBackFlags SelectionChanged="On" />
</ig:WebDataTree>
<ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource1" runat="server">
<DataViews>
<ig:DataView ID="HR_DEPT_DefaultView" DataMember="DefaultView"
DataSourceID="HR_DEPT" />
</DataViews>
</ig:WebHierarchicalDataSource>
<asp:SqlDataSource ID="HR_DEPT" runat="server"
ConnectionString="<%$ ConnectionStrings:hr %>"
ProviderName="<%$ ConnectionStrings:hr.ProviderName %>"
SelectCommand="select department_id, department_name from departments where manager_id is not null">
</asp:SqlDataSource>
</div>
<div>
<asp:SqlDataSource ID="emp1" runat="server" CacheKeyDependency="true"
DeleteCommand="DELETE FROM &quot;EMPLOYEES&quot; WHERE &quot;EMPLOYEE_ID&quot; = :EMPLOYEE_ID"
InsertCommand="INSERT INTO &quot;EMPLOYEES&quot; (&quot;EMPLOYEE_ID&quot;, &quot;FIRST_NAME&quot;, &quot;SALARY&quot;, &quot;DEPARTMENT_ID&quot;) VALUES (:EMPLOYEE_ID, :FIRST_NAME, :SALARY, :DEPARTMENT_ID)"
SelectCommand="select sub.department_id,sub.DEPARTMENT_NAME,(select first_name from employees where employee_id = sub.manager_id) first_name,(select salary from employees where employee_id = sub.manager_id) salary,manager_id employee_id from
select department_name,department_id, manager_id from departments where department_id= :DEPTID
)sub"
UpdateCommand="SALARY_UPDATE" UpdateCommandType="StoredProcedure" onselecting="emp1_Selecting"
<%-- UpdateCommand="UPDATE &quot;EMPLOYEES&quot; SET &quot;FIRST_NAME&quot; = :FIRST_NAME , &quot;SALARY&quot; = :SALARY WHERE &quot;EMPLOYEE_ID&quot; = :EMPLOYEE_ID" >--%>
<DeleteParameters>
<asp:Parameter Name="EMPLOYEE_ID" Type="Decimal" />
</DeleteParameters>
<SelectParameters>
<asp:controlparameter name="DEPTID" controlid="Labelx" propertyname="Text" DefaultValue="280"/>
</SelectParameters>
<InsertParameters>
<asp:Parameter Name="FIRST_NAME" Type="String" />
<asp:Parameter Name="SALARY" Type="Decimal" />
<asp:Parameter Name="DEPARTMENT_ID" Type="Decimal" />
</InsertParameters>
<UpdateParameters>
</UpdateParameters>
</div>
<asp:ScriptManager ID="ScriptManager2" runat="server">
</asp:ScriptManager>
<asp:UpdatePanel ID="pnl2" runat="server">
<ContentTemplate>
<asp:Button ID="btn_save" runat="server" Text="Save" onclick="btn_save_Click" />
<asp:Label ID="Label1" runat="server" Text="Label"></asp:Label>
</ContentTemplate>
</asp:UpdatePanel>
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="653px"
style="margin-right: 259px" AutoGenerateColumns="false"
DataKeyFields="EMPLOYEE_ID" DataSourceID="emp1">
<Columns>
<ig:BoundDataField DataFieldName="DEPARTMENT_ID" Key="DEPARTMENT_ID" Width="100">
<Header Text="DEPARTMENT_ID" />
</ig:BoundDataField>
<ig:BoundDataField DataFieldName="DEPARTMENT_NAME" Key="DEPARTMENT_NAME" Width="100">
<Header Text="DEPARTMENT_NAME" />
<ig:BoundDataField DataFieldName="EMPLOYEE_ID" Key="EMPLOYEE_ID" Width="100" Hidden="true">
<Header Text="EMPLOYEE_ID" />
<ig:BoundDataField DataFieldName="FIRST_NAME" Key="FIRST_NAME" Width="100">
<Header Text="FIRST_NAME" />
<ig:BoundDataField DataFieldName="SALARY" Key="SALARY" Width="100">
<Header Text="SALARY" />
</Columns>
<Behaviors>
<ig:EditingCore AutoCRUD="true">
<Behaviors>
<ig:CellEditing>
</ig:CellEditing>
<ig:RowAdding>
</ig:RowAdding>
<ig:RowDeleting />
</Behaviors>
</ig:EditingCore>
<ig:Selection CellClickAction="Row" RowSelectType="Single">
</ig:Selection>
<ig:RowSelectors>
</ig:RowSelectors>
</Behaviors>
</ig:WebDataGrid>
<br />
<asp:SqlDataSource ID="abcDS" runat="server"
ConnectionString="<%$ ConnectionStrings:hr %>" InsertCommand="ABC_INSERT"
InsertCommandType="StoredProcedure"
DeleteCommandType = "StoredProcedure"
DeleteCommand="ABC_DELETE"
SelectCommand="select * from abc">
<InsertParameters>
<asp:Parameter Name="A" Type="String" />
<asp:Parameter Name="B" Type="String" />
<asp:Parameter Name="C" Type="String" />
</InsertParameters>
<DeleteParameters>
</DeleteParameters>
<ig:WebDataGrid ID="abcGRID" runat="server" AutoGenerateColumns="False" DataKeyFields="A"
DataSourceID="abcDS" Height="350px" Width="400px">
<Columns>
<ig:BoundDataField DataFieldName="A" Key="A">
<Header Text="A" />
<ig:BoundDataField DataFieldName="B" Key="B">
<Header Text="B" />
<ig:BoundDataField DataFieldName="C" Key="C">
<Header Text="C" />
</Columns>
<Behaviors>
<ig:EditingCore>
<Behaviors>
<ig:RowAdding>
</ig:RowAdding>
<ig:RowDeleting />
<ig:CellEditing>
<CellEditingClientEvents ExitedEditMode="WebDataGridView_ExitingEditMode" />
</ig:CellEditing>
</Behaviors>
</ig:EditingCore>
<ig:Selection CellClickAction="Row" RowSelectType="Single" >
<SelectionClientEvents CellSelectionChanged="WebDataGridView_ExitingEditMode" />
</ig:Selection>
<ig:RowSelectors>
</ig:RowSelectors>
</Behaviors>
</ig:WebDataGrid>
</form>
</body>
</html>
