I have an Infragistics WebSplitter on an aspx page. I added the following Textbox control inside the splitter and after running the page found that the ID of the control had been changed to:
"WebSplitter1_tmpl0_TextBox1". The "WebSplitter1_tmpl0_" was added by the splitter.
This doesn't happen to controls outside the splitter panes.
Why is this happening? How can I stop it? What are the consequenses of stopping this from happening? How can I possibly use JavaScript to find controls when they have random ID's?
Original code:
<asp:TextBox ID="TextBox1" runat="server"></asp:TextBox>
Choose View, Source on the page after running it and you see this:
<input name="WebSplitter1$tmpl0$TextBox1" type="text" id="WebSplitter1_tmpl0_TextBox1" />
Thank you!
Hello raywhite ,
The behavior that you mentioned is by design- you can notice that similar issue is happening if you define your controls in form which is placed inside a master page, if you use ItemTamplates and so on.
In order to resolve this you can just set ClientIDMode="Static" to all of the controls that you want:
<asp:TextBox ClientIDMode="Static" ID="TextBox1" runat="server"></asp:TextBox>
For additional reference on the matter you can check the following link:
http://msdn.microsoft.com/en-us/library/system.web.ui.clientidmode.aspx
If you need any additional assistance on the matter please feel free to ask.
