Batch Updating and Activation enabled and Row Updating client event together give a bug:
Microsoft JScript runtime error: Unable to get value of the property 'postBack': object is null or undefined.
There are as well other combinations of behaviors which can cause that. It's hard to say what else exactly can cause that, because I have many behaviors and client events.
One thing for sure - this error goes away if you disable Batch Updating.
I attach sample solution.
Hello Andrey,
The fix for work item 127496 has been adressed in service release versions ASP.NET_12.2.20122.2031, ASP.NET_11.2.20112.2225 and ASP.NET_12.1.20121.2137.
Please do not hesitate to contact me if you continue to experience any issues after applying the latest service release.
Thank you for choosing Infragistics !
The next Service Release for NetAdvantage for ASP.NET is projected for the second half of December.
I have created a support ticket for you regarding this matter - CAS-105216-S2B2C2 and will link it with the existing development item, so that you will be automatically notified when a fix is available for this issue.
Thank you for choosing Infragistics.
Thank you very much for a quick response. When will it be available? Because it's really crutial for our solution... (Yes, I can think of workarounds, but it will be hell for us -we have 71 page with grids). But I understand that you just released a new SR, and even here http://ko.infragistics.com/help/service-releases/ the date is not yet updated.
Hi Andrey,
You are correct that this is a bug. It has been submitted internally as 127496 and should be in a future service release.
regards,David Young
