245
3D Pie Chart errors
In the 3d pie chart I have set leaderlines to thickness of 2.
VS2005
Now every time I change the LeaderDrawStyle and LeaderEndStyle, they always return to Dot and ArrowAnchor at runtime, and it crashes visual studio at design time.
Am I missing something?
Another problem is with the legend margins: evey time I set the left margin to 30, top, right and bottom margins remaing at the default 5, VS2005 crashes and the values ate changed. The left remains 30, but the other values are set to "0".
I am using VS2005 with 7.3 for web, but I also have VS2008 installed with 8.0... is this likely to have an impact on the problems I am experiencing?
  • 28496
    can you test this with the latest available hotfix?  i think the crash you're describing has been fixed.  if it's the problem i think it is, then VS2008 is not the cause of the problem.
