Good day All,
Hope you can help me.
I have an ASP.NET 4.0 Web app using Infragistics Netadvantage 11.2, SR 2141, with a web explorer bar that has a template that shows a radio button list of 10 items, used as a questionnaire. Each item template can be repeated more than once on the form due to it being a questionnaire. When the users use IE 8 WITHOUT compatibility mode, when clicking an item, it seems as if some unknown invisible markup is being added to the page (we do nothing client side on an item click, only when posting to the server), causing the page to widen. A particularly long questionnaire can lead to a very awkward looking page. When they activate compatibility mode, then this does not happen, but this is not the desired behaviour as it causes other issues. I can also confirm it does not happen when using IE 9 without compatibility mode, which is the desired effect. However, we need Ie 8 compatibility as some clients are still running Windows XP that does not support IE 9.
Anyone encountered this before or have some advice?
Just to let everyone know, all our issues as described above were resolved by upgrading to NetAdvantage v12.2, SR 2054.
Hello Eduard,
Thank you for your replies.
Let me know if you experience any issues after testing.
Upgrading to the latest NetAdvantage 2012.2 with the latest service release solved the problem, it seems. After some more testing I'll confirm if it worked 100%.
Hi Nikolay,
We finished the upgrade on our dev system to 2012.2, and the latest service release for same. It seems as if it has fixed our problem, it also fixed an issue we had with the WebDataMenu as well. We still have to do more system testing overall to ensure everything is working fine, but so far it looks good.
Thanks for the feedback.
P.S. :) The updater application did not upgrade our app to the latest version completely (some pages still had references to the old 2011.2 libraries), although it claimed it had been successfull in the upgrade. We thought the problem was still there and were about to log a service call, before my manager realized what was actually the matter.
:) Just an FYI.
We are doing an upgrade today to NetAdvantage 12.2 to see if an issue with another control has been fixed (the WebDataMenu), so we will test the WebExplorerBar as well before we attempt to take the changes to Staging and Live.
