200
WebDatePicker fails to render when disabled then re-enabled in a hidden roweditcontrol
I currently have a problem for which I find no solution at the moment
When my data is in a certain state, I disable editing and set some controls to set_enabled(false) in order to disable editing but permit reading data from the rowedittemplate
When data is in an editable state, I set the controls enabled with set_enabled(true) again, but when I open the rowedittemplate, the default value has disappeared and the drop down button which opens the calendar is greyed, as if the control was not rendered correctly
I tried using the _repaint() method, but it doesn't seem to work...
I'm proceeding to those actions via the rowDeleted and rowAdded events where I check data state
If someone was kind enough to help, that would be really nice
PS: extracting an exemple is not an easy option due to the project dependencies, so something like an indication of the best practice is welcome, so I can find a way to improve behavior
Thanks a lot!
