I would like add the ultrawebgrid export with UltraWebGridExcelExport in a excel template like this :
Workbook oTemplate = Infragistics.Excel.Workbook.Load("Template.xls");
ExcelDealExporter.Export(dealsBlotter, ws);
I have this error :
I don't understand why ...
You can use the Workbook.Load static method to load an existing workbook file. Then you can modify the data and save it out to the same or a different file name.
Hi, could you please explain me how to call a workbook which is already created and has data in it (same as your template file).
I am dont know how to declare and import. Appreciate your help
This looks like a bug. I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
