In the code behind, I select the last row in the grid.
var selectedRows = this.webDataGrid.Behaviors.Selection.SelectedRows;selectedRows.Add(this.webDataGrid.Rows[rowIndex]);
The row is selected but I don't see it because of the scroll pane.
How to automatically scroll to the selected row?
Thanks.
Hi Karthikeyan,
never mind, finally it works. Thanks for the help.
thanks for the reply. I tried the methods which present in the link you mentioned. But no luck, it is not at all scrolling to the selected row.
Please refer this.
Re: Webdatagrid - scrollIntoView
It helped.
I am facing similar problem, if I use the scrollToView() method the scrollbar is not moving to the selected row.
Please infragistic team, provide solution.
Even iam facing similar issue. Were you able to fix it? Please provide your inputs.
