Hi all!
If you take a look at
http://www.imscargo.com/content/en/company/figures/weight.aspx
you can see a LineChart with negative data.
As you can see the line between 2004 and 2005 ends in the label.
How can I avoid this?
Thanks for you respone
Hello polfi ,
I’m just following up to see if you have any other questions or concerns about this.
If so let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Thanks for your response.
So I have to read all data from the datasource before I bind it to the Chart....
That's what I want to prevent, but I will check if this works.
Hello polfi,
You could set a custom range type for the Y axis. You can check the documentation on how to set a custom range for an axis here:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=Chart_Axis_Ranges.html
Let me know if setting the range would work for you.
