1965
webdatatree binding to dataset
I have a webdatatree and i want to bind it to a dataset which contains a datatable with 5 rows. i only want the "name" values in the datatable to come in at the root node. How do i get this done?can someone provide me a working example? Similar situation with the child node.Please help!
  • 29417
    Hello dev_here ,
    I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
    Best Regards,
    Maya Kirova
    Developer Support Engineer
    Infragistics, Inc.
  • 29417
    Hello dev_here
    You’ll need to define the bindings for the tree in the DataBindings collection of the tree. For example if you have a parent table named “Parent” and you want to use a field named “Item” as the text field and another one called “id” for the ValueField you’ll need to define a DataTreeNodeBinding that looks like this:
    <ig:DataTreeNodeBinding DataMember="Parent" TextField="Item" ValueField="id" />
    The DataMember will define which one of the tables the specific binding should use. The Text and Value fields define from which columns the nodes should get their text and value.
    The same logic applies to the child nodes binding definitions.
    Please refer to the attached sample and let me know if you have any questions.
    Best Regards,
    Maya Kirova
    Developer Support Engineer II
    Infragistics, Inc.
    WDT_DataSet.zip
