I am using Infragistics35.Web.v11.2. Have a WebDropDown that connected to SQL data source. DisplayMode=DropDown. It fires SelectionChange event when I type first matching letter. If I have 2 items start with "F", it fired event when I type F and automatically select first item. I want this event fire when I select full item. Can't find right property.
Hello arkgroup,
I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Hello arkgroup ,
You can set AutoSelectOnMatch="false" for the drop down. That property is true by default which was causing that behavior.
Let me know if you have any questions or concerns.
Developer Support Engineer II
