799
Moving dropdown to current value
I'm continueing with a problem found in
http://ko.infragistics.com/community/forums/t/76517.aspx
I've implemented the solution, but when I open the dropdown, my entire content of my tab moves up.
(see printscreen)
What can i check to resolve this?
  • 29417
    Verified Answer
    Hello Razieltje ,
    Are there perhaps any other scrollbars on the page?
    The scrollIntoView() might be affecting them as well.
    To scroll only the container you could do something like this:
    function wdd1_opened(sender, e) {
              var selected = sender.get_selectedItem();
              var container = sender._elements.DropDownContents;
              var offset = $(container).first().position().top;
              if (selected != null) {
                  $(container).scrollTop(0);
                  var childElement = selected.get_element();
                  var top = $(childElement).position().top - offset;
                  $(container).scrollTop(top);
    This uses the jQuery’s scrollTop method. Since we call this only on the parent container it shouldn't affect anything else on the page.
    Let me know if you need further assistance with this.
    Best Regards,
    Maya Kirova
    Developer Support Engineer II
    Infragistics, Inc.
