Hi there,
I'm using a webdatagrid and have batchUpdating enabled. I add all my rows client-side with this
function AddMarks() { var grid = $find("<%=wdgMarks.ClientID %>"); //var row = new Array(grid.get_rows().length, "ExamMarkId", "ExaminationId", "Mark", "Enhanced", "DateModified", "ModifiedBy"); // create a new empty row var mark = $get("<%=ddlMarkFrom.ClientID%>").value + $get("<%=ddlMarkFrom2.ClientID %>").value; var row = new Array(grid.get_rows().length+1, $get('<%=hfExamID.ClientID %>').value, mark, $get("<%=chkEnhanced.ClientID %>").checked , "<%=DateTime.Now.ToShortDateString() %>", "<%=Page.User.Identity.Name%>"); // create a new empty row
grid.get_rows().add(row); }
The markup for the grid is
<ig:WebDataGrid ID="wdgMarks" runat="server" AutoGenerateColumns="False" DataSourceID="edsMarks" EnableAjax="False" Height="350px" Width="100%" onrowadding="wdgMarks_RowAdding" onrowsdeleting="wdgMarks_RowsDeleting"><Columns> <ig:BoundDataField DataFieldName="SomeId" Hidden="True" Key="SomeId" ><Header Text="SomeId" /></ig:BoundDataField><ig:BoundDataField DataFieldName="SomethingElse" Hidden="True" Key="SomethingElse"><Header Text="SomethingElse" /></ig:BoundDataField><ig:TemplateDataField Key="Mark"><Header Text="Mark" /><ItemTemplate><%# Goddard.DAL.Utility.IntToBase26((int)DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Mark"))%></ItemTemplate></ig:TemplateDataField> <ig:BoundCheckBoxField DataFieldName="Enhanced" Key="Enhanced"><Header Text="Enhanced" /></ig:BoundCheckBoxField><ig:BoundDataField DataFieldName="DateModified" Key="DateModified"><Header Text="DateModified" /></ig:BoundDataField><ig:BoundDataField DataFieldName="ModifiedBy" Key="ModifiedBy"><Header Text="ModifiedBy" /></ig:BoundDataField>
</Columns><ClientEvents KeyDown="wdgMarks_Grid_KeyDown" /><Behaviors><ig:EditingCore AutoCRUD="False" BatchUpdating="True"><Behaviors><ig:RowAdding Enabled="False"></ig:RowAdding><ig:RowDeleting /></Behaviors></ig:EditingCore><ig:Selection CellClickAction="Row" RowSelectType="Single"></ig:Selection><ig:RowSelectors></ig:RowSelectors></Behaviors></ig:WebDataGrid>
and that all seems to work fine.
However, when I post-back I get an error stating that
Line: 4211Error: Sys.InvalidOperationException: Cannot serialize non finite numbers.
That happens a few times, then the page does it's postback, but none of the grid update events are fired.
Please advise.
Found the problem, the row adding, i was not starting at 0, once i do that works fine.
