3550
Jquery with Ajax
I am using Jquery code,   txt.css("background", "red"); which I expect to color my WebNumericEditor  in red.
I put the DialogWindow in an Update panel, triggered by a button.
I press the button to show the dialog window.
 The window shows, but WebNumericEditor  is not red
Without the updatepanel, the code works properly.
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Pricer.aspx.cs" Inherits="OptionPricer.Pricer" %>
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.2054, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI.EditorControls" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI" TagPrefix="ig1" %>
    Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
<html xmlns="http://www.w3.org/1999/xhtml">
<head id="Head1" runat="server">
    <title></title>
    <script type="text/javascript" src="jquery-1.7.1.js"></script>
        $(document).ready(function () {
            var txt = $("#txtStrikeAmount")
    </script>
</head>
<body>
    <form id="form1" runat="server" >
    <ig1:WebScriptManager ID="WebScriptManager1" runat="server">
    </ig1:WebScriptManager>
    <asp:UpdatePanel ID="UpdatePanel4" runat="server">
        <ContentTemplate>
              <ig:WebDialogWindow ID="WebDialogWindow1" CssClass="EditDialog" runat="server"  InitialLocation="Centered"
        Modal="True"  ViewStateMode="Enabled" Top="0">
        <Header>
            <MaximizeBox Visible="True" />
            <MinimizeBox Visible="True" />
        </Header>
        <Resizer Enabled="True" />
        <ContentPane BackColor="White">
            <Template>
                <div dir="rtl" class="Edit-container">
                    <div class="StrikePremContainer">
                        <div float="right">
                        </div>
                        <div class="StrikePremEdit">
                            <ig:WebNumericEditor  ID="txtStrikeAmount" runat="server"
                                ClientIDMode="Static" MinValue="0" Nullable="False">
                            </ig:WebNumericEditor>
                        </div>
                    </div>
                </div>
            </Template>
        </ContentPane>
    </ig:WebDialogWindow>
        </ContentTemplate>
        <Triggers>
            <asp:AsyncPostBackTrigger ControlID="ButtonAdd" EventName="Click" />
        </Triggers>
    </asp:UpdatePanel>
    <asp:Button runat="server" Text="Show Window"
        ID="ButtonAdd" onclick="ButtonAdd_Click" />
    </form>
</body>
</html>
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Data;
using Infragistics.Web.UI.EditorControls;
using Infragistics.Web.UI.GridControls;
namespace OptionPricer
    public partial class Pricer : System.Web.UI.Page
        //List<OptionValues> mOptionValuesLs;
        protected void Page_Load(object sender, EventArgs e)
            if (!IsPostBack)
                WebDialogWindow1.WindowState = Infragistics.Web.UI.LayoutControls.DialogWindowState.Hidden;
        protected void ButtonAdd_Click(object sender, EventArgs e)
            WebDialogWindow1.WindowState = Infragistics.Web.UI.LayoutControls.DialogWindowState.Normal;
P   בידך להשפיע על איכות הסביבה - אנא שקול את נחיצות ההדפסה
  • 29417
    Verified Answer
    Hello drpoalim,
    The function you set in  $(document).ready will only be executed on a full page postback. During a ajax postback not all of page’s Dom is re-rendered so that function will not be executed.
    You can hook an event for the PageRequestManager’s endRequest event. It will be fired right after the update panel is finished with its ajax request. For example:
                var txt = $("#txtStrikeAmount");
                Sys.WebForms.PageRequestManager.getInstance().add_endRequest(EndRequestHandler);
                function EndRequestHandler() {
    Best Regards,
    Maya Kirova
    Developer Support Engineer II
    Infragistics, Inc.
