I have WebDataGrid
<aspigtbl:WebDataGrid id="SS_EntitiesGrid" ShowFooter="false" runat="server" Width="98%" ImageDirectory="/ig_common/Images/" AutoGenerateColumns="false" ItemCssClass="igg_cb_Item" HeaderCaptionCssClass="igg_cb_HeaderCaption" on > <ClientEvents DoubleClick="OnDblClick" Initialize="OnGridInitializeGrid"/> <Columns> <aspigtbl:BoundDataField Width="25%" Key="Type" DataFieldName="Type" Hidden="False"></aspigtbl:BoundDataField> </Columns> <Behaviors> <aspigtbl:Activation Enabled="false" ActiveCellCssClass="igg_cb_ActiveCell"> </aspigtbl:Activation> <aspigtbl:EditingCore Enabled="true" BatchUpdating="true" AutoCRUD="false"> <EditingClientEvents RowUpdated="OnGridRowInsertHandler" /> <Behaviors> <aspigtbl:RowAdding Enabled="false"> </aspigtbl:RowAdding> <aspigtbl:RowDeleting Enabled="false" /> <aspigtbl:CellEditing Enabled="false" > </aspigtbl:CellEditing> </Behaviors> </aspigtbl:EditingCore> <aspigtbl:Selection CellClickAction="Row" RowSelectType="Multiple" CellSelectType="None" SelectedCellCssClass="igg_cb_SelectedCell" SelectionClientEvents-RowSelectionChanged="OnGridAfterSelectChange"> </aspigtbl:Selection> <aspigtbl:Sorting Enabled="false"></aspigtbl:Sorting> <aspigtbl:RowSelectors RowNumbering="true" Enabled="true"></aspigtbl:RowSelectors> </Behaviors>
</aspigtbl:WebDataGrid>
When I set value to the row and then set text, text value is override row value
row.get_cellByColumnKey(colKey).set_value(1);row.get_cellByColumnKey(colKey).set_text("text");
When I get_value(), I get value="text". Why?
Hello Anton,
You could directly use the set value function to set both the text and the value. The first parameter you pass to the set_value method will be the value set and the second will be the text. So for example if you set:.set_value(1,"txt");
And then get the value(get_value()), it will be 1. And the text(get_text()) will be “txt”.
Let me know if you have any questions or concerns.
Best Regards,
Maya Kirova
Developer Support Engineer II
Infragistics, Inc.
