I have a WebDropDown (v11.1, .Net 3.5) and have the "ALL" as the first item that helps in selecting all the items.
I have hooked up the ClientEvents "SelectionChanged" and "ValueChanged" to handle the "ALL" selection and it works fine. Only "ALL" is selected when all the items are selected.
But when i click a button that performs a postback, the WebDropDown has all items including the "ALL". Can this be overcome or am i missing something?
I found the answer myself but not sure if efficient.
I hooked the following ClientEvents "SelectionChanged", "DropDownClosed", "DropDownOpened". In DropDownOpened, I make all items to be selected if "ALL" is selected. In DropDownClosed, I make all items unselected EXCEPT "ALL". So, even in Postback the only "ALL" is displayed.
In case if it helps someone., here goes the code
function wdd_dropDownOpened(sender, eventArgs) { var items = sender.get_items(); if (items.getItem(0).get_selected() == true && items.getItem(0).get_text().toUpperCase() == 'ALL') { for (i = 1; i < items.getLength(); i++) { var item = items.getItem(i); item.select(); } }
} // -->function wdd_dropDownClosed(sender, eventArgs) { var activeIndex = sender.get_activeItemIndex(); var items = sender.get_items(); if (activeIndex == 0 && items.getItem(0).get_selected() == true) { sender.set_currentValue("ALL", true); for (i = 1; i < items.getLength(); i++) { var item = items.getItem(i); item.unselect(); } }
}function selectedIndexChanged(sender, eventArgs) { var activeIndex = sender.get_activeItemIndex(); var items = sender.get_items(); if (activeIndex == 0 && items.getItem(0).get_selected() == true && items.getItem(0).get_text().toUpperCase() == 'ALL') { for (i = 1; i < items.getLength(); i++) { var item = items.getItem(i); item.select(); } } else if (activeIndex == 0 && items.getItem(0).get_selected() == false && items.getItem(0).get_text().toUpperCase() == 'ALL') { for (i = 1; i < items.getLength(); i++) { var item = items.getItem(i); item.unselect(); } } else if (activeIndex != 0) { if (items.getItem(activeIndex).get_selected() == false) { items.getItem(0).unselect(); } }}
Ok, i have 2 questions now..
1. Is the above method efficient? Any other workarounds?
2. I have around 15 ASPX pages, can I create a Custom control to include the above Javscript to avoid repetitive code? Please suggest.
Forgot to add, I need the "ALL" alone to be displayed in the WebDropDown after postback.
When I have selective items, the WebDropDown displays the correct items.
