I am using the WebDialogWindow with Modal=True. When the Modal pops up, even though it is much smaller than the total screen area, it adds about a full screen's worth of blank space to the bottom of the website and causes the page to be able to scroll down when it shouldn't. This only happens in Internet Explorer 7. It seems to work fine in IE9 and Google Chrome.
Here's my sample code:
<%@ Page Title="Home Page" Language="C#" MasterPageFile="~/Site.master" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.2014, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI" TagPrefix="ig" %><%--ScriptManager--%><asp:Content ID="HeaderContent" runat="server" ContentPlaceHolderID="HeadContent"></asp:Content><asp:Content ID="BodyContent" runat="server" ContentPlaceHolderID="MainContent"> <ig:WebScriptManager ID="WebScriptManager1" runat="server"> </ig:WebScriptManager> <ig:WebDialogWindow ID="wdwTest" runat="server" Height="300px" Width="400px" Modal="true" WindowState="Hidden"> <ContentPane> <Template> <div> <asp:Button ID="btnClose" Text="Close" runat="server" OnClick="CloseWDW" /> </div> </Template> </ContentPane> </ig:WebDialogWindow> <asp:Button ID="btnOpen" Text="Open" runat="server" OnClick="OpenWDW" /> <br /></asp:Content>
using System;using System.Collections.Generic;using System.Linq;using System.Web;using System.Web.UI;using System.Web.UI.WebControls;
using Infragistics.Documents.Excel;using System.IO;using System.Data.OleDb;
public partial class _Default : System.Web.UI.Page{ System.Data.DataTable tblDates = new System.Data.DataTable();
protected void Page_Load(object sender, EventArgs e) {
protected void OpenWDW(object sender, EventArgs e) { wdwTest.WindowState = Infragistics.Web.UI.LayoutControls.DialogWindowState.Normal; }
protected void CloseWDW(object sender, EventArgs e) { wdwTest.WindowState = Infragistics.Web.UI.LayoutControls.DialogWindowState.Hidden; }}
Hello Brian,
I have investigated your issue, and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 133397. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I created a support ticket for your case with an ID of CAS-110734-C5N8R4. You can alse continue to send updates to this case at any time.
You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
Do not hesitate to contact me if you need more information.
Thank you for contacting Infragistics.
I recieved your support request concerning WebDialogWindow. I am currently looking into the issue and will get back to you soon with more information or questions for you.
