589
How to change the Row backcolor at the run-time.
HI,
The WebDataGrid (12.2.20122.2054) grid is loading the data from a data table and want specific rows to be highlighted in different back color.
The below code snipped is used to change the row's css class.
For intRow = 0 To UGData.Rows.Count - 1
objGridRecord = UGData.Rows(intRow)
If Trim(objGridRecord.Items(1).Text) = "sectionheader" Then
objGridRecord.CssClass = "ig_Item_Selected_about"
End If
Next intRow
The CSS Class is below
.ig_Item_Selected_about
font-size:13px;
font-family: verdana;
padding-left:1px;
font-weight: bold;
background-color:#b0eac0;
The row's font is bold, but backcolor  didn't change. Any ideas?
Regards, Karthik
  • 29417
    Verified Answer
    Hello Karthik,
    Thank  you for posting in our forum.
    The background-color needs to be applied to the cell elements so if you set the class like this:
    .ig_Item_Selected_about  >  td
    background-color:#b0eac0 !important;
    It should set the background color for the cells in the corresponding rows. And since it has the !important tag on it , it will overwrite the default settings that may come from the grid theme you've chosen.
    For more styling tips in the WebDataGrid you can refer to the grid’s styling guide:
    http://ko.infragistics.com/community/blogs/engineering/archive/2010/08/25/webdatagrid-css-styling-guide.aspx
    Let me know if you have any questions or concerns.
    Best Regards,
    Maya Kirova
    Developer Support Engineer II
    Infragistics, Inc.
