745
Get Current Index of Parent Row
I have a simple webhierarchicaldatagrid, and in the second band I have a template column with a button like the following:
<ig:WebHierarchicalDataGrid ID="wdgLOG" runat="server" AutoGenerateColumns="False"
Height="300" AutoGenerateBands="False" InitialDataBindDepth="-1" Width="100%"
DataKeyFields="Lote" EnableDataViewState="true" EnableAjax="false" DataMember="Files"
Key="Files">
<ExpandCollapseAnimation SlideOpenDirection="Auto" SlideOpenDuration="300" SlideCloseDirection="Auto"
SlideCloseDuration="300" />
<Columns>
</Columns>
<Bands>
<ig:Band DataKeyFields="ProcSourceFileID,ProcFileID" AutoGenerateColumns="false"
DataMember="FilesDet" Key="FilesDet" ShowHeader="true">
<Columns>
<ig:TemplateDataField Key="Audit" Width="16px" Header-Text="" Header-Tooltip="Ver Auditoria">
<ItemTemplate>
<asp:LinkButton ID="lbtnAudit" runat="server" Height="16px" CssClass="CmdAbrirAuditoria"
ToolTip="Auditoria" CommandName="CmdAudit" CommandArgument='<%# DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).Item, "Row.Index") %>'></asp:LinkButton>
</ItemTemplate>
</ig:TemplateDataField>
</Columns>
</ig:Band>
</Bands>
</ig:WebHierarchicalDataGrid>
When I click lbtnAudit Button I want to know what row I'm currently in, so I use ItemCommand Event:
Private Sub wdgLOG_ItemCommand(sender As Object, e As Infragistics.Web.UI.GridControls.HandleCommandEventArgs) Handles wdgLOG.ItemCommand
    If e.CommandName = "CmdAudit" Then
I know that the property CommandArgument gives the current row index and it works perfectly. But I need to know the index of the parent row too, because CommandArgument only gives the current child index...
How can I do this?
Thank you
