Since upgrading from 12.1.20121.1005 to 12.1.20121.2178 I have a problem with the first node clicked in the treeview retaining the active styling after I click on another node. See here for an example of the problem. The problem disappears when I click on any object outside the treeview.
My page is complicated by the fact that the WebDataTree is created as a template within a WebExplorerBar. Looking at the CSS, I think the first item clicked is being styled with the WebExplorerBar active item style.
I have created an example project that replicates the problem and attached it below.
Any help would be appreciated. I upgraded in the hope this would fix another bug, which it hasn't, just introduced this! Great!!
Hello Nick,
Thank you for your feedback and for sharing this with us.
Is has been a while since this issue was submitted. I am just checking about the progress of it. If you need further assistance, I will be glad to help you.
As an update, I have found a solution myself which I have posted below if anyone else has the same issue. However, it overrides my style sheets, and relies on the WebDataTree element structure remaining consistent, so if the Infragistics staff or anyone else can some up with a more elegant solution I would appreciate it.
My solution was to add the following script, the treeViewItemClick function being called from the WebDataTree item click event;
function treeViewItemClick(sender, args) { var selectedNode = args.getNode(); if (selectedNode != null) { var nodes = sender.getNodes(); for (var i = 0; i < nodes.get_length(); i++) { var node = nodes.getNode(i); clearNodeBackground(node, selectedNode); } } }
function clearNodeBackground(node, selectedNode) { if (node != null) { if (selectedNode.get_valueString() != node.get_valueString()) { node.get_element().childNodes[2].style.backgroundColor = "White"; } else { node.get_element().childNodes[2].style.backgroundColor = "#FFE474"; } // Now check if it has any children, do the same for each if so if (node.hasChildren()) { for (var i = 0; i < node.get_childrenCount(); i++) { clearNodeBackground(node.get_childNode(i), selectedNode); } } }}
