220
Help on Version Utility Upgrade 12.2
I just downloaded the 12.2 Version release and upgraded a solution from 12.2.20122.2014 to 12.2.20122.2075.  I did this to see if some IE 9 scripting errors (not showing up on IE 8 or on Firefox 10.X and great) get repaired.  The utility ran successfully but now my proejct will not run and I've tried all morning to get it back.
I am getting an error in RE to multiple versions being found of WebDataTree (the first page rendered for Navigation):
Compiler Error Message: CS0433: The type 'Infragistics.Web.UI.AjaxIndicator' exists in both 'c:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\1ff7be39\ca621514\assembly\dl3\4a8748aa\68002783_c803ce01\Infragistics4.Web.v12.2.DLL' and 'c:\WINDOWS\Microsoft.NET\assembly\GAC_MSIL\Infragistics4.Web.v12.2\v4.0_12.2.20122.2075__7dd5c3163f2cd0cb\Infragistics4.Web.v12.2.dll'
Any ideas??
  • 220
    Here is the content of the user control (that worked prior to upgrade):
    <%@ Control Language="C#" AutoEventWireup="true" CodeBehind="NavigationUserControl.ascx.cs" Inherits="KMInfoPostings.UserControls.WebUserControl1"%>
    <%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.2075, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.NavigationControls" TagPrefix="ig"%>
    <asp:XmlDataSource ID="XmlDataSource1" runat="server" ></asp:XmlDataSource>
    <script type="text/javascript"" id="UPClientScript">
    function WebDataTree1_NodeClick(sender, eventargs) {
    __doPostBack("updContent", ');
    function WebDataTree1_SelectionChanged(sender, eventargs) {
    __doPostBack("updContent", '');}
    </script>
    <ig:WebDataTree ID="WebDataTree1" runat="server" Height="100%" Width="100%" DataSourceID="XmlDataSource1" InitialExpandDepth="1" OnDataBound="WebDataTree1_DataBound" >
    <ClientEvents NodeClick="WebDataTree1_NodeClick" SelectionChanged="WebDataTree1_SelectionChanged"/>
    <DataBindings>
    <ig:DataTreeNodeBinding DataMember="SiteMap" TextField="Title" ValueField="URL" NavigateUrlFields="URL"/>
    <ig:DataTreeNodeBinding DataMember="element1" TextField="Title" ValueField="URL" NavigateUrlFields="URL"/>
    <ig:DataTreeNodeBinding DataMember="element2" TextField="Title" ValueField="URL" NavigateUrlFields="URL"/>
    <ig:DataTreeNodeBinding DataMember="element3" TextField="Title" ValueField="URL" NavigateUrlFields="URL" />
    </DataBindings>
    </ig:WebDataTree>
