405
pane.set_contentUrl() to use ajax_indicator()
We are using a WebSplitter and calling from javascript the "pane.set_contentUrl()" method to load a page into a splitter pane.
Unfortunately it seems the WebSplitter doesn't support the global ajaxIndicator (at least I couldn't find it anywhere - the splitter.get_ajaxIndicator() returns null).
How can we implement such functionality in the WebSplitter?
Thanks in advance
  • 24497
    Hi Leon,
    The ajaxIndicator is related to asynchronously loaded content similar to content of submitted UpdatePanel. The $IG.LayoutPane.set_contentUrl(...) sets src of iframe, and that is completely different functionality.
    It is possible to show an indicator when src is modified and hide that indicator when iframe was loaded. Similar is used as a built-in functionality of WebTab to show progress of newly loaded url (mostly if tab was not visible on initial load or when new tab was added on client). But WebSplitter does not target similar scenario: in most cases splitter panes are visible on start.
    I wrote for you a sample, which uses IG.AjaxIndicator to show loading progress when src of splitter pane was modified (assumes that you want to load url into first content pane of WebSplitter1)
    var ai;
    function loadUrl() {
    var splitter = $find('WebSplitter1');
    var cp = splitter.getPaneAt(0);
    cp.set_contentUrl(http://ko.infragistics.com);
    var
    iframe = cp.get_iframe();
    if (!ai) {
    ai = new $IG.AjaxIndicator(null);
    ai.set_imageUrl("ig_res/Default/images/ig_ajaxIndicator.gif");
    //ai.set_css("ig_AjaxIndicator");
    //ai.set_blockCss("ig_AjaxIndicatorBlock");
    //etc. custom settings
    ai.set_enabled(true);
    ai.set_relativeToControl(true);
    ai.setRelativeContainer(iframe);
       ai.show();
       $addHandler(iframe, 'load', function () { ai.hide(); } );
    </script>
    <input type="button" value="LoadUrl" onclick="loadUrl()" />
  • 7499
    Hello Leon,
    As WebSplitter does not use any internal async postback, this feature is not supported.
    Please let me know if You have any further questions regarding this matter.
