How can I postback when I use the keyboard to change the value in the WebDatePicker? I know how to accomplish this by selecting from the calendar.
Thank you,
Trent
Hello Trent,
Thank you for your feedback. I am glad that you managed to resolve the issue.
We value your input, and our philosophy is to enhance our toolset based on customer feedback.
Please let me know if I can be of any further assistance.
Hi Vasya,
I managed to get it working by adding the Javascript. However, I don't feel that is the right solution. I used Infragistics control because it is suppose to write all that code for me. Why should I enable something to postback and then have to write the Javascript code to postback.
I was wondering did you have a chance to try my suggestion? Please feel free to contact me if you have any additional questions regarding this matter.
What I can suggest for achieving your requirement is handle WebDatePicker`s KeyDown event which is fired even when the DateTimePicker is on focus. In the event current text being entered is accessible via sender`s get_text() method as such: sender.get_text(); . Please note that string returned from this method contains everything visible in the input textbox of the DatePicker, including the slashes used to separate the date ("_2/__/____"). What I can suggest is take this string, split it by the slash("/") symbol and check whether the input is a valid date. If the input is a valid date a CallBackManager object for the WebDatePicker control may be executed to cause a PostBack as such:
var callbackObject = sender._callbackManager.createCallbackObject(); sender._callbackManager.execute(callbackObject);
I hope this helps.
Hi Trent,
There is no AutoPostBackFlag, which would trigger postback when calendar is closed. Application has to process client events and trigger postback.
