I have a grid with some hyperlinks in it. I need to export it to PDF and Excel. ApplyFormula appears to be gone which used to be the correct way in Excel. This seems a little odd that it isn't handled automatically considering it already knows that it's a hyperlink(<asp:HyperLink ID="HyperLink1").
So what am I missing?
Does anybody know what property has all the url data in it? It's interesting that the text property is empty, yet the PDF shows the url.
I came up with this for excel, now I'll have to see if I can figure out something for PDF. I'll also add, for some reason the compiler didn't complain without the reference to Infragistics4.WebUI.Documents.Excel.v13.1, but it was required (it adds ApplyFormula)
protected void WebExcelExporter1_CellExported(object sender, Infragistics.Web.UI.GridControls.ExcelCellExportedEventArgs e) {
string cellContents = e.WorksheetCell.Value.ToString(); int iStartPos = -1; int iEndPos = -1; int iEndPos2 = -1; string newValue = "=HYPERLINK("; string friendlyName; if (cellContents.Contains("HyperLink")) { iStartPos = cellContents.IndexOf("href="); iEndPos = cellContents.IndexOf(">", iStartPos + 5); iEndPos2 = cellContents.IndexOf("<", iEndPos + 1); friendlyName = cellContents.Substring(iEndPos + 1, iEndPos2 - iEndPos - 1); if (iStartPos != -1) { newValue += cellContents.Substring(iStartPos + 5, iEndPos - iStartPos - 5) + ",\"" + friendlyName + "\")"; e.WorksheetCell.ApplyFormula(newValue); } else { e.WorksheetCell.Value = friendlyName; } } }
