45
Numeric column sorting changes depending upon number of pages
I really need some assistance, please and thank you!  I have a webdatagrid which is populated in code behind using a datatable.  If the search query returns fewer records than the page size, then a numerica data column sorts properly (according to numeric values, such as 1.1, 1.2, 3.0, 8.1, 12.1, 13.2, etc.).
However, if the search query returns more records than will fit on one page, then the numeric column appears to sort by string values (1.1, 1.2, 12.1, 13.2, 3.0, etc.)
It has been unfailing all afternoon.  I have tried setting the DATATYPE= property of the column in question to several different values to no avail.  There appears to be nothing I can do to retrieve the records in the correct sequence with a multi-page result.
The data column in question is an Oracle number column.
Thanks in advance for any help!  This is driving me nuts!
Lynn
