935
WebTextEditor with NullText cannot be cleared via Javascript
Hi All,
I am using Infragistics v11.2.20112.2086. I have two text boxes with the NullText property set.
a. The user enters a value in TextBox A
b. clicks a checkbox to copy the value to text box B.
c. When the user then clears text box A, it clears text box B successfully via a javascript function.
postalField.set_text(source.get_text());
However, if step a is skipped, i.e. text bos B is not given a non-blank value initially, then this text box can never be completely blank. If the user enters text in text box A and immediately clears the text in text box A, the text box B is not cleared.
I have confirmed that if If I leave NullText property blank for the text box, this issue does not exist.
I am currently setting the value to " " if it sender.get_text() if it is blank and this seems to fix the issue for now.
Is there any other alternative to solve this problem?
Thanks!
