I am using 2012 volume 1. It seems that when I post back to the server, the value in the WebDateTimeEditor field is gone. Does anyone know why?
Trent
Hi Trent,
Thank you report.Recently there was an issue submitted for similar situation when trigger of postback was not a "submit" button which triggers form onsubmit event, but a control which uses __doPostBack(...).Javascript in Ifragistics.Web.UI was adjusted to support that scenario. If your application also had triggers with __doPostBack, then I expect that coming service releases will support original application without "work around" which you applied.
I found out that I needed to set ScriptManager with EnablePartialRendering="true".
