I am using NetAdvantage 12.2 and have implemented a solution using the webhierarchicaldatagrid. I have given up trying to use the webhierarchicaldatasource with stored procedures...it's just too broken (I guess?) and have gone to a code behind solution using datarelations to populate the bands. Now I want to turn off the autocolumn and autoband features and write the band and column control manually using markup. I have the top level markup working to control the columns.
But I can't get the Band markup to recognize my markup. I would like to see an example of:
codebehind using datarelations and manual markup of the whdg uilitzing multiple bands with column control.
Any help will be appreciated, TIA, Jim Spicer
Hello Jim,
I am glad you managed to resolve this issue. Thank you for your feedback and for sharing this with us. Other community members could benefit from such threads.
Hi again,
Well noone replied so below is the direction I am now trying...maybe it will help someone else.
Public Sub LoadWHDG(ByVal strVendorsID As String, ByVal strUsersDataID As String)
WebHierarchicalDataGrid1.DataSourceID = Nothing 'clear the control
WebHierarchicalDataGrid1.DataBind()
Dim ds As New System.Data.DataSet Dim dt As New System.Data.DataTable
ds.Tables.Add(GetPOReport(0, "Jobs" & Session("CoName"), "VendorProjects" & Session("CoName"), "dbo.usp_getVendorPOListByVendor", strVendorsID, strUsersDataID, True)) dt = clsCustParams.GetLineItemsFromVendorsID(strVendorsID, Session("CoID"), Session("ProjID"), "Transactions" & Session("CoName"), "Jobs" & Session("CoName"), "Types" & Session("CoName"), True) ds.Tables.Add(dt)
Dim relJobs As New DataRelation("Jobs", ds.Tables(0).Columns("Job_ID"), ds.Tables(1).Columns("Job_ID"), True)
ds.Relations.Add(relJobs)
' Create band Dim childBand As New Band() childBand.DataKeyFields = "Job_ID"
' Set the key from the data source childBand.Key = "Job_ID" ' Set the data member from the data source to bind to childBand.DataMember = dt.TableName
Me.WebHierarchicalDataGrid1.AutoGenerateBands = False Me.WebHierarchicalDataGrid1.Bands.Add(childBand) Me.WebHierarchicalDataGrid1.Bands("Job_ID").AutoGenerateColumns = False
Dim boundField As New BoundDataField(True) ' Define column for the child band boundField = New BoundDataField(True) boundField.Key = "Date" boundField.Header.Text = "Date" 'Bind to Product ID field in data source boundField.DataFieldName = "Date" childBand.Columns.Add(boundField) childBand.Columns("Date").Width = 80 '--------------------------------------------DATE boundField = New BoundDataField(True) boundField.Key = "Estimate" boundField.Header.Text = "Amount" boundField.DataFieldName = "Estimate" childBand.Columns.Add(boundField) childBand.Columns("Estimate").Width = 100 '--------------------------------------------AMOUNT boundField = New BoundDataField(True) boundField.Key = "Description" boundField.Header.Text = "Description" boundField.DataFieldName = "Description" childBand.Columns.Add(boundField) childBand.Columns("Description").Width = 200 '--------------------------------------------DESCRIPTION WebHierarchicalDataGrid1.DataKeyFields = "Job_ID"
WebHierarchicalDataGrid1.DataSource = ds
End Sub
Jim
