I turned batched flag to true, works fine so far... I forget what to do so 'undo' box would appear on mouse over... I used to see it on the grid that I worked before but do not remember how to turn it on. Thnx.
Thanks, now I recall it, I have had delete in other grid... thanks
Hello mcseidel,
Thank you for contacting Infragistics. What changes are you making that you are expecting the Undo button? Are you making cell edits, deleting rows or both? As you can see in the following documentation the undo button will only appear for deleted rows.
http://help.infragistics.com/NetAdvantage/ASPNET/2013.1/CLR4.0/?page=WebDataGrid_Batch_Updating_Enabling.html
For undoing edits you should have that row selected where you want to undo the edits and press ctrl + z.
Are you unable to see the undo button for deleted rows? If this is the case what version of NetAdvantage are you using? What service release are you using?
Sincerely, Mike P. Developer Support Engineer II Infragistics, Inc. www.infragistics.com
