Is there a way to hide WebDatePiceker control from server side? If I set visibility to false, control is not rendered so I can not unhide it from UI side. I would like to avoid adding some additional containers and then changing their visibility.
I am just following up to see if you need any further assistance with this matter.
In order to hide/show control from on client side you need to hide control in the client side Initialize event of WebDatePicker as shown below:
function WebDatePicker1_Initialize(sender, eventArgs) {
sender.set_visible(false);
<ig:WebDatePicker ID="WebDatePicker1" runat="server" ClientIDMode="Static"> <ClientSideEvents Initialize="WebDatePicker1_Initialize" /> </ig:WebDatePicker>
You can unhide the control later in client side script as below:
var datepicker = $find("WebDatePicker1");
datepicker.set_visible(true);
I hope this helps.
