3550
pressing ColumnResized doesnt reach render.
I have a custom server control, which I created with my own design.
I put it in an update panel together with a grid.
I activated the  OnColumnResized.
When the user changes the size of a column I want to reach the render of my custom control and change its apearance.
In debug, when I put breakpoint, it doesnt reach the Render function.
(It does reach though, the pre render)
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Linq;
using System.Text;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
namespace PortalControls
    [DefaultProperty("Text")]
    [ToolboxData("<{0}:PortalButton runat=server></{0}:PortalButton>")]
    public class PortalButton : LinkButton
        protected override void Render(HtmlTextWriter output)
            output.Write(BuildHTML());
        private string BuildHTML()
            return "xxx";
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Pricer.aspx.cs" Inherits="OptionPricer.Pricer" %>
<%@ Register Assembly="OptionPricer" Namespace="PortalControls" TagPrefix="cc1" %>
<%@ Register Assembly="Infragistics4.Web.v12.2, Version=12.2.20122.2054, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI.EditorControls" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI" TagPrefix="ig1" %>
    Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
    Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd ">
<html xmlns=" http://www.w3.org/1999/xhtml ">
<head id="Head1" runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server" >
        <ig1:WebScriptManager ID="WebScriptManager1" runat="server">
        </ig1:WebScriptManager>
        <asp:UpdatePanel ID="UpdatePanel4" runat="server">
            <ContentTemplate>
                    <ig:WebDataGrid ID="PricerDataGrid" runat="server"
                        ClientIDMode="Static" AutoGenerateColumns="False"
                        OnColumnResized="PricerDataGrid_ColumnResized">
                        <Columns>
                            <ig:BoundDataField DataFieldName="PremPrecent" DataType="System.Double" Key="ColPremPercent"
                                <Header Text="prem" />
                            </ig:BoundDataField>
                            <ig:BoundDataField DataFieldName="PremAmountCalulated" DataType="System.Double" Key="ColPremAmount"                            >
                                <Header Text="prem amount " />
                        </Columns>
                        <Behaviors>
                            <ig:ColumnResizing>
                                <AutoPostBackFlags ColumnResized="True" />
                            </ig:ColumnResizing>
                        </Behaviors>
                    </ig:WebDataGrid>
                    <div class="btnMainTable">
                        <cc1:PortalButton ID="btnDelete" runat="server" Text="delete" ClientIDMode="Static"
                            OnPreRender="btnDelete_PreRender"></cc1:PortalButton>
                    </div>
            </ContentTemplate>
            <Triggers>
                <asp:AsyncPostBackTrigger ControlID="PricerDataGrid" />
            </Triggers>
        </asp:UpdatePanel>
    </form>
</body>
</html>
using System;
using System.Linq;
using System.Web;
using DealingRoom.Utils.BasicManiputlations;
using DealsRoomDAL;
using System.Data;
using DealingRoom.Utils.BuisnessDays;
using Infragistics.Web.UI.EditorControls;
using Infragistics.Web.UI.GridControls;
using OptionPricerCalculator.Objects;
using OptionPricerCalculator;
using System.Globalization;
namespace OptionPricer
    public partial class Pricer : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
            PopulateGrid();
        protected override void OnLoadComplete(EventArgs e)
            base.OnLoadComplete(e);
        protected void btnDelete_PreRender(object sender, EventArgs e)
        public void PopulateGrid()
            List<OptionValues> ls = new List<OptionValues>();
            ls.Add(new OptionValues());
            PricerDataGrid.DataSource = ls;
            PricerDataGrid.DataBind();
        protected void PricerDataGrid_ColumnResized(object sender, ColumnResizingEventArgs e)
