1175
Multiple Visible-Calls causes errors
Hello there,
in reference to my other question, subdatagrid, I have a problem calling multiple times the visible attribute:
When the user presses a button, I show the datagrid with
dgrIndRoleAttributes.Visible = true:
After pressing the button again, I just redo this with the
dgrIndRoleAttributes.Visible = false;
If I press the button again, so I want visible = true again, I get the error that the control with the same ID allready exists. Does Visible = False remove the control or does it just set the CSS?
Is there a bug in my code which causes such error or should I not use this property on that way?
Thanks for your response
Matthias
