I have read numerous forum posts regarding MissingRecordException, but none of them could clarify my issue yet. Unfortunately, some of the provided links (to forum posts as well as to knowledge base articles) are broken and can not be accessed any more.
Scenario:I have got a WebDataGrid, which is bound to an ObjectDataSource. The ODS again works with a custom ViewModel (return type = List<ViewModelItem>). The grid allows for adding new entries, copying existing entries, editing entries (in-place edit) and deleting entries.The grid is configured for batch updating, sorting and filtering is done inside the view model. All CRUD operations are handled manually.
Issue:Everything works as intended, except copying an existing entry. Usually, the user copies a few entries and updates their values, then copies a few more and updates those and so on. This works most of the time.Sometimes tho, it seems that the grid is getting confused. When the user clicks to copy another entry, he will receive a MissingRecordException and loose all changes made so far.Looking at the grid in the debugger reveals the following: Normally it would contain entries with - for example - unique position numbers 1 to 14, but right before the exception is thrown the inner list would show double position numbers while others are missing (like: 2, 2, 4, 4, 7, 7, 8, 8, 10, 10, 12, 12, 13, 13 => still 14 in total, but messed up).
Interestingly, the following code prevents the grid from throwing the exception and everything works fine:
protected void SampleItemDataGrid_DataBound(object sender, EventArgs e){ List<string> ckList = new List<string>(); foreach (GridRecord rec in SampleItemDataGrid.Rows) { ckList.Add(((SampleItem)rec.DataItem).CompositeKey); }}
I am pretty sure that I missed out on something, but I could not figure it out from all the posts and articles I have read. I would be happy to get pointed in the right direction here or to be provided with an extensive sample on WebDataGrid and ObjectDataSource.
I have attached more code (aspx and aspx.cs) at the following links:http://pastebin.com/cikmXZUEhttp://pastebin.com/kbDZSKAfIt has been simplified and shortened, since the original .aspx file is more than 3k lines long.
Hello weirdal ,
I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Are you using the clipboard behavior when copy/pasting similar to the example here:
http://ko.infragistics.com/products/aspnet/sample/data-grid/clipboard
If not could you let me know exactly how is copy an entry implemented in your application and exactly what steps are needed in order to reproduce the issue?
It would be helpful if you could attach a sample that demonstrates the issue you’re encountering.
I’m looking forward to your reply.
Developer Support Engineer II
bump
